B
Bullet Bob
Guest
"I have a 1996 Trojan 350 Expr
"I have a 1996 Trojan 350 Express with twin Crusader 454 TBI HO 350hp engines. The engines have 400hrs. I did my winter maintenance projects recently: changed oil & filters; replaced Racor fuel filters and fuel filters at the throttle body; changed plugs, wires, distributor cap and rotor. I took the boat out for a test run after doing my maintenance and discovered that the Stbd engine would only grab about 3500 rpm's while the port engine would get 4500 rpm'd at WOT.
I thought that it might be a fuel starvation problem so I did a pressure test of the fuel system which recorded 20psi for both engines.
I never had a problem before with the engines performance. Both engines have always performed equally as well. Now I'm at a loss. What should i be looking for??"
