Last June I replaced the crankshaft/balancer timing cover seal and thought that that had corrected the oil leak, but it didn't. So now I plan to replace the timing cover, oil seal, and all gaskets. I ordered and received the new cover which comes with the crankshaft/balancer seal already installed, and all the other needed gaskets. Yesterday I removed the belts, balancer, water circulating pump, sea-water pump and brackets. I then removed the old timing cover, cutting off the old gasket between the timing cover and oil pan as directed in the Crusader manual.
Here are my questions and concerns.
Should I use some black RTV sealant on both sides of the semi-circle bottom gasket, i.e. between the cover and gasket and also between the gasket and the oil pan?
What about using sealant on the other gasket between the cover and the block?
And what about the water pump to block gaskets? Dry or with some sealant?
Any and all suggestions welcome!
Erich
Erich
