Folks...I'm at my wits end with the 1 3/8" shaft couplings on my boat...its tight to work on them...I'v tried everything...PB blaster in the holes ...heat with a socket in between them pinched with longer bolts. I used my propane torch to heat with and kept heat just above comfortable to touch...do I need to get them hotter...maybe use a mapp torch? I really don't want to cut them off. I'm trying to change the shaft log hose out ....the yard mechanic says they still look good and arent cracked but gee wiz they been on the boat for 23 years. If I have to cut the coupling off by splitting it over the keyway Can I source just the shaft half? Where? Thanks for any help.
