Crusader 454 manifold and risers
temerick
I am having the manifolds and
I am having the manifolds and risers on both engines replaced. Does anyone know how many hours of labor this takes?
"Ayuh,.. That usually depends
"Ayuh,.. That usually depends on how much Boat has to be removed to get To them..."
The boat is a Tiara 36 express
The boat is a Tiara 36 express. The access is pretty good. I am wondering if the manifolds need replacing. I dont think the see anything but antifreeze. Am I correct?
"Bondo makes a great point. I
"Bondo makes a great point. It took me several weekends to do the first engine. But, circumstances were one of corrosion, age and experience. Internally, it was rather extreme. The manifolds might have looked ok, but their overall wall thickness HAD to be compromised thru the cast iron flaking away."
"Crusader flat rate is 1.5 hrs
"Crusader flat rate is 1.5 hrs. per side (3.0 per engine), that's a bit tight. Add for draining and refilling cooling system if FWC. 8-9 hrs should be accurate for a pair of FWC engines with decent access including clean-up and test run. Corroded bolts are a whole other story.
Rick"
"Well you didn't give me m
"Well you didn't give me much information to base a decision on but the 454 has not been used since 2000 and if they have never been changed, you're past due."
Ted; put your FWC manifolds o
Ted; put your FWC manifolds on a 20 year replacement shedule. Any double wall salt water elbows and risers on a 4 year schedule.
"Checked mine at 1300 hrs /22
"Checked mine at 1300 hrs /22 years of service, Raw water cooled, great lakes boat, large capacity strainers. both engine`s manifolds were in top notch condition. Gotta love sweet water !!"
"Interesting info on the manif
"Interesting info on the manifolds, replaced risers/elbows two yrs ago but not maifolds. Boat is a 31' 1988 Tiara with 454s. The manifolds looked fine with no water trails down into them.
How can I tell if they have ever been replaced? Here is a pic of the bottom of one.
Manifold
Typical rust pattern around th
Typical rust pattern around the exhaust ports. They run super hot compared to the rest of the manifold (or the engine for that matter).
Jeff
