rockmeister
"Hey group I am new to the for
"Hey group I am new to the forum and to boating. I am looking into a 1986 Wellcraft Grandsport.
I am looking for you opinions.
1-this quote seems high.
2- The work proposed seems to me that I could do it myself. What do you think? Rather than cleaning an oil cooler wouldn't it be best to buy new ones? Same for the generator..and in your opinion and experience how hard is it to replace exhaust elbows and risers?
I have a machanical report and this is what it says:
CHECKED COMPRESSION ON BOTH ENGINES AND
VISUALLY INSPECTED EQUIPMENT IN ENGINE ROOM..
....PORT ENGINE IS 135,135, 150, 140, 135, 135, 140, AND 135
...STBD ENGINE IS 130 ,125, 130, 115, 125, 125, 125, AND 130
BOTH ENGINES HAVE GOOD COMPRESSION FOR THE
AGE OF THEM,,
----PORT ENGINE HAS OLD HOSES AND NEWER HEAT
EXCHANGER,,ENGINE STARTED AND RUN WELL,,,
RECOMMENDED CHECKING EXHAUST RISERS,,,
-----STBD ENGINE HAS OLD HOSES , RUSTED AND
LEAKING EXHAUST ELBOWS, RECOMMEND REPLACING
BEFORE IT MAKES A BIGGER PROBLEM.. ENGINE
STARTED FINE AND RUN WELL
----GENERATOR HAS BROKEN EXHAUST ELBOW AND
HOSE, RUSTED EXHAUST POT AND ,, UNIT IS RUSTED
BUT IT DID TURN OVER...
---BATTERY CONNECTIONS ARE LOSE...
Quote to fix:
GENERATOR,, exhaust elbow is broken , exhaust pot is rusted on bottom , metal fuel line is corroted
PORT ENGINE.oil cooler needs cleaning, old hoses on cooling system they are original.
STBD ENGINE.. exhaust elbows are rusted and leaking , dirty oil cooler , dirty heat exchanger.. old hoses on cooling system..
price on generator exhaust elbow is 260.00 you are looking at
---- 500,00 parts and labor to make genrator run and stop exhaust leak
--1000.00 to clean port oil cooler and replace bad hoses...
---1100.00 to replace stbd exhaust elbows parts and labor..
---650.00 to have stbd oil cooler and heat exchanger serviced ,, parts and labor
---800.00 to have stbd hoses replaced parts and labor
Looking to the boards before I get ripped by the broker and/or his buddy mechanic.
Also, Iam planning on, if bought, to deliver it myself by sea about 125 (road) miles to final destination. Thoughts?
Thanks."
AGE OF THEM,,
Quote to fix:
Thanks."
