"Great thread. Have laid low
"Great thread. Have laid low reading topics since buying my 1st twin-screw last month..1988 27' Phoenix Fishbuster w/ 350 Crusaders (270xl's)w/ 675 hrs ea. Great boat so far w/ everything: Floscan, windlass, Sinrad AP, electronics galore..now to just figure out how to operate & maintain it all....
Could use some advise resolving an eng rpm sync issue. At idle, twin Floscan tachs agree @900rpm, but @cruise of 22mph, port reads 2200 & starboard @3000 as it should. I DO NOT feel the pull to to port as you'd expect w/ real 800 rpm difference, and motor noise seems equivalent. If I up the port throttle, that motor gets louder, but still don't feel the pull to starboard you'd expect either? Port does run a little hotter (150-160) vs stbd @ 140f. I've had props pulled and reconditioned, but no change. Note the upper helm station tachs (separate guages) agree w/ the lower helm Floscan @cruise. Unfortuneately, Floscan fuel meters not working properly, so can't see if diff in port vs starboard consumption (am working on that problem too). @WOT, Stbd shows 4000 & Port 3100. Starting to think port motor is really running slower, but can't confirm. Have cleaned port carb in place (Qjet) & Starboard carb appears to be newer. Any suggestions on where to start?
Also, port motor starts hard & stalls @idle when cold & damp, but runs like a champ once warm. Not sure if related."
