corvett350
Hi I have a 1988 silvetron 30X which was running fine until the belt on the starboard engine broke. The engine overheated and shout down. I replaced the belt but the engine continued to overheat. I replace the thermostat it started running hot . I replaced the risers now the engine reaches operating temperature (160) at a much faster rate than the port engine. I also had to fill the heat exchange with anti freeze and saw some in the bilg. The water pump does not appear to be leaking . What can I do to fix this problem?
