S
SilvertonRay
Guest
"Running a Silverton with dual
"Running a Silverton with dual 270s ... Port is standard rotation and running 165/170 tops. Starboard is counter rotation and running 190/195 too close for comfort. Engines were overhauled in Nov last year. New trans and new vdrives.
When sitting at the dock, I took off the caps to watch the water flow. Flow looks good on the port, on the starboard, the more gas I give her, the less water flow I am getting, which I assume is the problem.
Impeller looks good - Had the local shop peep the pump and all seemed well. The strainers are all clog free, and I had boiled out the exchangers at same time of the overhaul, but not checked at the moment.
Looking for ideas and suggestions - Maybe someone has had the same problems along the way. Thanks in advance for any hints, tips, thoughts, theories and suggestions!"
