" I have a 32' Trojan with
" I have a 32' Trojan with twin Crusader 270s (350CI small block chevy) Over the weekend while running at about 2800rpm, the starboard engine stalled and we smelled gasoline so I shut the port engine down as well. There was a strong odor of gasoline in the bilge. So, after being towed home, I checked every single fuel hose, fitting and connection. I could not find any evidence of a fuel leak or any gasoline anywhere except in the bilge, neither could a mechanic I hired. I first thought the needle valve on carb on the starboard engine was stuck and flooded the engine which would explain the loss of power, but not the gasoline in the bilge because it is a marine carburetor; (Rochester quadrajet) and has a plastic line from the float bowl to the fuel pump. I then thought the fuel pump was the culprit, but if the fuel pump diaphram was ruptured, there would be gasoline in the oil and there isn't. Both engines start and run fine now with no sign of fuel leaking. I have worked on automotive versions of this engine for over thirty years but I am at my wits end. "
