"Hello all,
Here is the sto
"Hello all,
Here is the story, I bought a 1986 29' Phoenix Sportbridge from New York and had it shipped to Texas. It was a fresh water boat (Lake Ontario). The boat sat for over a year. I got the boat and ran it. The temps on the starboard engine when I would run at about 3000 RPM Would approach 190 (port is about 180). Temp would go down when I slowed down. I believe I read that 195 is max, so I did not let them get there. Also when I try to dock the boat and have the throttles to idle, the starboard engine dies and I have to restart, after it dies, the port will sometimes as well. Even though the gas had stabil in it, I suspect I have bad gas. I put some Star-Tron in the tanks on the recommendation of a mechanic. I have not noticed any difference after adding the Star Tron, but i have only put about 13 miles on the boat total, so probably not enough to show yet. I have also read that they use heavier engine oil up north due to the cold and that perhaps this is making the engine run a little hot. I know nothing about engines, and had a mechanic scheduled to come give it a once-over. He stood me up twice, so no more. I pulled the fuel/water seperators and the starboard was a little rusted at the bottom. The port looked fine (but then I really don't know what I am looking at). I also pulled the spark arrestor/breathers to look at the carbs. I would like to know how to tell what carbs they are (probably qjets from what I read). They looked ok, but I don't know what they would look like if they were bad. I didn't do a complete inspection, only what I could see from the top down after removing the breather. I would appreciate Jeff or Mako or any of you coming in with helpful suggestions. Here are a few questions:
1. Does anyone know a good crusader mechanic who works in Freeport Texas?
2. Can I run the gas out of the boat?
3. If they did run a heavier oil due to the cold in New York, could that be causing the engine heat?
4. Where do you add transmission fluid (how can I tell which transmissions I have)
5. My seacocks for the engines are on the bottom of the bilge, seems impossible to get to them, they have a wingnut type screw in the bottom, do I just have to undo this to clean them, or do they come apart and there is a filter. Many of you will probably think I should not have bought a boat knowing so little, but offshore fishing is my passion and I am willing to learn. Anyone who knows crusaders very well is invited for a free fishing trip!
Thanks in advance for your help.
Shannon
Since the boat has been sitting, i am of a mind to just run her good and "blow the pipes", I am just afraid I might blow something else (expensive). It has oil, transmission fluid, and will have new fuel filters, can I run it without doing harm (will head back if temps get close to 190)
I would also like to install some things to make life easier for doing things like backflushes like I read on here with a clear PVC hose hooked to the cooler to watch the flow."
Here is the sto
"Hello all,
Shannon
