foodwatch2003
"I have a Chrysler 360 that ha
"I have a Chrysler 360 that had been recently rebuilt by a previous owner. I have installed new exhaust manifolds, rebuilt the Carter carb, and replaced the original distributor with a mallory electronic one. There is also a rebuilt Arco starter motor. The engine has been idle for nearly 3 years with all these improvents.
To get it ready, I removed all plugs, squireted cylinders with Marvel, removed distributor and gear and rotated the oil pump clockwise with a drill and confirmed oil pressure was good. Then put in new plugs, new wires and reset the distributor so that the #1 distributor port pointed toward the #1 cylinder. I have spark on all cylinders when engine cranks. The battery and all battery connections are clean and making solid contact. The engine seems to crank about half normal speed and is not enough to get it to do more than a few pops. Unfortunately, I cannot get to the timing marks the way the engine is in the boat, so I adjusted the distributor to fire #1 at the best compression point on #1. After a little bit of cranking (30 secs) the starter battery post is discolored and I see some smoke coming from the post. The #4 cable going to the starter is warm, but not hot. It seems to me that the starter may have some internal corrosion on the 12v terminal. I also hear a "clunking" sound that goes with each complete rotation of the engine. Anyone have any symptoms like this? It will not even start with ether injected into the carb. It tries to fire, but the engine is cranking too slow.
Ed"
Ed"
