"OK, another one in the endles
"OK, another one in the endless series of 15hp rebuild questions...
How close is the fit between the crankcase cover and cylinder block supposed to be? If I place the crank cover on the block, without any bolts, and shine a light at the seam, I can see a very thin stripe of light when peering into the crankcase. Is this normal?
The reason I'm asking is that the mating surface on the crank cover looks like somebody used some pretty coarse sandpaper to remove a gasket, so I'm wondering whether this might affect the fit. History & running condition of engine is unknown.
I don't have a measurement for the gap, but even where it appears to be largest, my thinnest feeler gauge (0.05mm/0.002") isn't even close to fitting in. So I'm guessing it could be something in the ballpark of 0.02 mm or 0.001"."
