Crank
"thats a good question.......w
"thats a good question.......well can you buy bearings for a outboard crank thats been turned?......thats probably the kicker cause im sure it can be turned.
ive read lots of threads but i dont think ive read one where its been done, maybe someone will fill us in."
"outboards(modern) are
"outboards(modern) are all roller bearing equiped,and to my knowledge,OEM or aftermarket,do not supply oversize bearings.turning the crank,should not be a prob at all,and crank repair,back to standard,is done all the time."
"but at what cost can the cran
"but at what cost can the crank be fixed? wouldnt a new one be cheaper?.....those machine shops are very proud of their work, course they have some very expensive equipment"
"[b]but at what cost can the c
That depends on the extent of damage.
That depends on the cost to repair.
OB crankshaft, main and rod, journals are repaired by welding up then grinding and polishing to spec. Often at a fraction of the cost of new."
