I'm in the process of converting twin 5.7's from the Sherwood belt driven pump to the Johnson crank driven pumps.
I have a question regarding the belt drive pulley that drives the Sherwood. Do you remove this pully and bolt the Johnson pump directly to the balancer? I have not removed this pulley yet but it appears that a shorter bolt for the harmonic balancer would be required as currently this bolt with a washer underneath is one of 4 bolts holding the Sherwood pulley on and will extend further into the crank end once the pulley is removed.
Thanks in advance for the combined wisdom of this forum.
