"Hi all - I'm a first-time
"Hi all - I'm a first-time poster but have been utalizing this board for a while now. I've reached a point where a simple archive search probably won't give me the info/advice I need. Sorry if this is a bit wordy.....
Last year, I acquired a 1970 Buehler Turbocraft jet boat. The boat had seen very little action in it's lifetime and was all-original....including 318. Before I even put the boat in the water, I replaced the metal gas tank (varnished gas and all), copper fuel lines and fuel pump. I then ran it for one weekend in Sept. Knowing that would probably be my last usage of the season, I winterized it.....believing to have followed proper procedures. I didn't go crazy knowing it was going to be kept in climate-controlled storage starting in late Nov.
Unfortunately, we had an early freeze before it went to storage and, to my surprise, I blew a couple of freeze plugs. In addition to being surprised that the coolant hadn't found it's way throughout the block, I discovered that most of what had blown them out was frozen sediment/lake sand (maybe that's why the coolant didn't make it throughout).
I went through the winter keeping my fingers crossed that the plugs popping had saved the block. Today, I put in the new plugs and fresh oil and filter. She fired up right away and ran very smoothly (on the hose). After about 30 seconds of running, I shut it down and pulled the dipstick.....the fresh oil was now fresh milk. So, after the long intro, here's where I need some advice......
Short of a teardown, is there a way to determine, for sure, that it's the block (vs. a head gasket, etc., etc.) or....under the circumstances of the plugs popping, do I spare myself the time, effort and cost of trial and error and go right for a new block?
Note that, pre-winterization, oil was uncontaminated and compression was good in all 8.
Ultimately, now that we're in mid-June, I'm trying to prevent myself from my standard MO....which would be to take the long road to solving the problem.
Thanks in advance for reading....and for any and all advice.
Greg"
Greg"
