firemanlowden
I have a 1977 Galixy given to
I have a 1977 Galixy given to me with a cracked block form my uncle. I have repaired the crack with JB WELD changed the milky oil and ran for 30 min with the mufs. The boat ran perfect like there was nothing wrong with it. BUT there was water in the oil again. I have also noticed when I used a spray bottle and sprayed the seam between the intake and the head there were bubbles there. I used the same intake gasket. would it be a bad seal or the fact that the block was cracked to let water back in the oil? Also the block has no outer water leaks anymore. Will there still be hidden water in the engine I wasnt able to get cause the milky oil and just need a few oil changes to clear it out? Thank you
