What's the difference between a Sierra Ignition coil part# 18-5437 and part# 18-5433 ? I have twin 1990 OMC 5.7L Cobra's in my FourWinns 315 Vista, and one week ago my port engine would not start after running great this summer and the past 8 yrs. The starboard engine ran great. So I tried the usual replacements including dist cap, rotor, spark plugs and checked much of the wiring, connectors, wire terminals, etc. So I swapped the ignition coil from the starboard engine and it worked good and started the port engine. So I bought two new ignition coils part# 18-5433 because I think they were the original coils and figured if one was bad I might as well replace them both. I trusted the parts counter person sold me the correct parts. So now both engines ran great....for about 15 minutes.....about 10 minutes to idle out the river, and 5 mins on plane going apx 30mph at apx3500rpm...then I slowly lost engine power over apx 1-2minutes untill I could no longer run the engines above 1000rpms because it would cough and sputter... So now after some WEB research it looks like they sold me the WRONG IGNITION COILS....I believe I need the part# 18-5437 coil. So I want to know what is the difference between the two coils? And could using the wrong coils for 15 minutes have now caused my engines to run terrible? They seem to idle ok, but spit and sputter when I give throttle and are worse when under way and pushing the boat and terrible when I try to get on plane. What could the wrong coils have damaged on both engines to react the exact same way? I don't think some other unrelated failure is occurring (ie: water in gas) ....that would be too much of a coincidence. Any help would be greatly appreciated.
