"I seem to be having a problem
"I seem to be having a problem with corrosion on my KAMD44-p. It's on a pursuit 3000, 1998, and is the Stardboard engine. The front of the engine is starting to corrode. I checked all the ground wiring inside the hull and can't find anything loose. Is there a wire on the alternator to check or something else I'm missing?
Second - I live in Florida and have warm water all the time. Is the normal operating temp of 180 degrees OK (no load), and around 200 -205 under load or cruising OK?
Frank"
Frank"
