chief_wiggum
"Just trying to figure out IF
"Just trying to figure out IF I have a problem or not... I've gone completely through the cooling system on my 86 Bayliner, and everything is in good shape. It has a 180' stat in it, and when idling in the water it will stay there all day. Once you get running though, the temp climbs (slowly) to ~200 (hard to tell exact temp with vague crap Bayliner gauge).. It doesn't *seem* to be running hot. Doesn't smell hot, not spitting out coolant, etc but I just want to know what is considered normal..
Just FYI.. here's what I have done as preventive maint.
replaced seawater impeller, seals and drive cog, replaced the seals that go into seawater pump. installed a garden hose fitting with clear 5/8 hose between transom and metal water intake, removed disassembled cleaned and re-installed heat exchanger... found ZERO corrosion inside. Removed / tested / re-installed t-stat. Removed inspected and re-sealed intake hose and elbow on outside of drive.
The only things I found that were suspect were the following.
1. the coolant appeared to be STRAIGHT 100% coolant.
2. intake elbow looked like it had been sucking air. there were marks on the flange when disassembled.
3. seawater pump- impeller was a bit hard / stiff. good shape, but didn't seem as pliable as it should be.
Sorry for the lon-winded post. just wanted to give a clear picture of where I'm at.
thanks for advice.
-randy"
thanks for advice.
-randy"
