- [h=2][/h]
1986 19 Ft. Searay Seville
4.3 OMC Cobra
Recent purchase
The two line that go from the tilt/trim pump to the port behind the transom plate were leaking.
Pulled engine as I needed to installed new long block anyway.
Both lines appear to have been rubbed and pinched by the coupler.
Replaced both lines and ran them the same as the old ones--which appears to be the only option. The lines basically set between the exhaust"Y" outlet and the coupler.
Put new engine in and it appears the coupler will rub on them.
Would someone know the correct routing , or better yet a photo?
Thanks for any help
