coollent in oil
saltairtwo
Atfer the winter storage went to change the oil and found coollent in the oil a small amount , how and where would the coolent get into the oil pan ,
The motor ia 270 crusader (350 chevy block) fresh water cool has not run since last fall . Where do i look for the leak ??? and what the repair ???
I would try a pressure tester on the system and see how quickly the pressure drops. It is posible that you have a head gasket going. Dont start it till you figure things out as it will screw things up royaly for you. Good luck.
