I have a 1983 Evinrude 70hp and it starts right up and seems to run good but overheats. I get no water out of the tell-tale. The waterpump was just replaced a couple of months ago and it was pumping good afterwards. I had problems with the stator and replaced it but now it won't pump water. I removed the thermostat housing and fired it up and get exhaust pressure and no water out the thermostat hole. What would cause exhaust pressure to enter the cooling system, bad exhaust manifold? Bad Head Gasket (although I would think if it was that bad it wouldn't even run)? Cracked block? What do the experts think before I start tearing it down?
