Cooling Question 1967 Johnson 95 MQ13M
blaydesfl
This motor has run no problems
This motor has run no problems for 3 years. Started it up this morning after it had sat for a month. On the first start the water expelled out of the back hole was running a continues stream. On the second start and all starts after no continues stream. I do not want to burn up the engine so I stopped. Is this a water pump problem? Why all good on the first start then no stream of water after second start.
Any suggestions are greatly appreciated.
"Bob... Water pumps fail at so
"Bob... Water pumps fail at some given point, a point that no one can foresee. Time to drop the lower unit to inspect the pump."
"Quite easy UNLESS the water t
"Quite easy UNLESS the water tube happens to pull out of the powerhead.
Remove lower unit bolts, drop lower unit enough so that you can remove one bolt from the shift connector..... that's it."
