Cooling Problems
josie
"I have a DT25C that will not
"I have a DT25C that will not pump water. I have checked all the flow paths. I can get water thru all the tube up to the block and out the weep hole using a water hose. I have replaced the water pump impeller with no success. I have noticed that there seems to be a "pulsing" pressure coming from the weephole and the thermostat opening when the motor is running but no water is coming out. The compression on all cylinders is between 83-85 so I don't think it is a blown head gasket leaking compression into the water jacket. I was wondering if it may be exaust leaking into the water jacket but wasn't sure where it would be leaking by? Any ideas? Is there something else I should be looking at. The engine runs fine without any problems, but it will not pump water to the motor.
Thanks,
Josie"
"1987 suzuki 55hp the water di
"1987 suzuki 55hp the water discharge was comingout very weak and the motor overheated. I changed the water pump, had good discharge for about 3hours of hard running, then the discharge again became weak and the motor once more overheated. I once again changed the water pump. Again had good discharge for about a half an hour. Again discharge became weak and engine overheated. The compression test read between 115 and 125 on the cylinders. Each time the impellar looked fine. I blew out all of the the lines with compressed air. Any ideas would be appreciated."
