Sorry, I am in Kansas around the Fort Riley area. Gaskets are on correctly. I had a mechanic come and help me get those on so that they would be right, plus I didn't want to pull the distributor out by myself so he helped me do that part. The temp gauge is saying I am not overheating, but the left side water coming out you can put your hand under. It is hot, but normal. The right side is twice as hot and I can barely put my hand under it. I have checked everything I can think of. What is this flapper you keep mentioning? I took my bottom end of the drive off to check the pump and make sure I got the hose for the water pickup connected good. All is okay there to include the impeller. Could there be air locked in that one side preventing it from getting enough water? I had a friend that put a crate motor in his boat and he said it did the same thing with the muffs on it, but as soon as he put it in the water it sucked enough water and cleared it up. I am open to any and all suggestions. I do not want to overheat and ruin a good motor. Thanks
