dangit'sme
So, I took care of my coolant leaks, new engine. Ran the engine for 25 minutes, never came up to temp. My infra red gauge showed 111degrees at thermostat housing, all parts of engine were no higher than 100 degrees. Exhaust elbows were at 95 degrees. Exhaust hoses were running hot, 200 degrees. Heat exchanger was at 110 degrees. Is the heat exchanger leaking into the engine, thereby keeping the engine cool? How do I test this?. Do I take off an end cap on the exchanger and see if there is any antifreeze in there? Also, does it matter where I place the hoses for the hot water heater? I don't remember where I took them off from. I know all the hoses are correct for the exchanger, from pictures. I'm at a loss, never had a non-overheating problem.
Thanks in advance,
Richard
Thanks in advance,
Richard
