Cooling Hose from drive to sheild 1993 DPC
bryanm
"I pulled my outdrive today an
"I pulled my outdrive today and was very surprised at the deteriation since last year of the "S" hose from the drive to the shield. I am going to replace it as it is very stiff and in poor condition. I am looking at parts book and it is showing no clamp on the shield end of the hose. My question is does this just pull off at this end or is it clamped with a lip inside the small "manifold" Volvo is calling a hose nipple?
I'd post a link, but nobody has a DP-C diagram online and I can't scan a book at home."
"It is not shown here, but I b
"It is not shown here, but I believe that there is a clamp at this end of the suction hose.
I'd also install a new water neck fitting if I were you.
http://www.marinepartseurope.com/PentaPictures500/9265.jpg"
BTW, If you do not know this already......, I'd strongly suggest that you pull the transmission from the Intermediate housing first. This makes the balance of the work much much easier!
Likewise, install it last when re-assembling your drive. "
You have to remove the pipe on
You have to remove the pipe on the inside. The hose has a collar on the inside which seals when the pipe screws are torqued down.
"I should have added:
In man
In many cases, removing the entire drive is un-necessary. Entire drive removal (as a unit) adds to the difficulty, regardless of work scope!
In addition, with the transmission ONLY out of your way, this suction hose and water neck fitting that you are working on (and the shift cable bracket), all become easily accessable.
This is also the easiest method to use when replacing Drive Bellows. Much moreso than if you were attempting to remove or hang an entire drive as a unit!
"I already pulled the whole dr
"I already pulled the whole drive. But I will take the advice and reinstall the upper seperately. With just the single engine, the inside fitting was fairly easy to get to. Now I just need the replacment hose to arive."
