"hello im a newbie here and ha
"hello im a newbie here and had just bought my first boat, its a 1981 180 cuddy, it has a mercruiser 470 in it. well the first problems i encountered was the coolant leak from the water pump cover area so i had a marine tech replace just the seals, i then had the carb rebuilt and engine tuned up with new plugs wires and new cap and rotor and new thermostat. engine starts right up and has no electrical issues or starting issues. 1 thing i noticed was the coolant overflowing from the radiator cap area, i replaced the cap but it still continues to overflow. the motor does not overheat so far. what are some things i should look into as far the cooling system, i know i should replace the water impeller in the out drive as far as a maintanence requirements. what are some things to consider, also iu broke a small thin tubing that connects to the trim area in the back of the boat, i ordered a new hose which was only 22 bucks. the fluid leaked out and im not sure how to fill her back up and what to fill her up with. the hose coonects to a box looking object which i know its for the trim because when i raised the trim fluid was leaking out of the broken hose. the hose's diameter is actually smaller than a straw kinda the size of a vaccum hose but its a hard white plastic."
