I recently changed manifolds &
I recently changed manifolds & risers on my 1998 Mercruiser 7.4's inboards. Since then whenever I run the boat my starboard engine heats up slowly and will occasionally overflow the overflow tank. Even when that doesn't occur as the engine cools I lose at least a quart of antifreeze. I replaced the heat exchanger cap with a lower pressure cap and the amount of lost antifreeze has decreased to a pint or so. Where is it going? I pressure tested the heat exchanger and looked to see if any coolant was leaking into the raw water side with no luck. The pressure does seem to slowly drop. My oil is fine. Can coolant be leaking into the exhaust manifold and out the exhaust as the engine cools? Any thoughts will help. I'm considering having the heat exchanger looked at and serviced but it seems that it must be related to the manifold job that I did.
