Converting Velvet Drive from 191 to 11
G
George S
Guest
" Is it possible to convert a
" Is it possible to convert a 1.91 geared Velvet Drive box to 1:1 or is it a major drama?
I have a 1.91 Borg Warner Velvet Drive box to sit behind a 4108 Perkins to drive a 23' displacement cruiser. The Engine/Box combination is a little bit longer than it should be for the boat, so I am considering converting the box to 1:1 by removing the extension housing. Is that possible without major expense or hassle, or should I shop around for a 1:1 box? "
" George, keep in mind that th
" George, keep in mind that the B/W 1.91 gear reverses the actual rotation of the engine. It is the only B/W gear to do so. If you change to a 1:1 gear you will have to change the prop also. Kim "
" Hi Kim and thanks for your a
" Hi Kim and thanks for your advice. At this stage the engine/gearbox combo is new to the boat as my previous engine carked it! So, I will need to re-prop anyway. "
" Just one more thought, to go
" Just one more thought, to go from a 1:91 to a 1:1 gear is a huge jump. Can you get the performance you want even with a prop change. Good Luck and keep us posted, Kim "
"i keep blowing front seal in
"i keep blowing front seal in trans what is the problem ,,, rebuilt by company and put in by same they are a t a loss need help!!!! [email protected]
thanks
Tim"
