R
rob reminder
Guest
hello all. i'm considering
hello all. i'm considering going to a thru hull exhaust on my 1975 searay. it currently has a 888 mercruiser with the y- pipe to outdrive. i have end riser log style manifolds and was thinking of changing the risers to 15 degree and routing the exhaust thru transom. has anyone done this? i don't want to spend 2 grand on a custom stainless setup. i also found a center riser cast iron manifold setup that fits ford 302/351 engines that might work as well. the problem with the center riser manifold setup is that it only has one water hookup as oposed to the three i currently have. any help would be appreciated.
