sandkicker
Outstanding Contributor
"Anyone done this successfully
"Anyone done this successfully??? Friend of mine doing this (replacing original log style manifolds/elbows with OSCO center rise). From looking at the water flow diagram of this system, it appears as if one can just:
1) remove the "T" in the raw water line that feeds the pressure relief valves.
2) Plumb the engine just the way it was (out of circulator pump, into back of exhaust manifolds and out of top of manifold (front) port into block)...and
3) use the standard "partial block" gasket between the centerrise manifolds and the exhaust elbows.
4) Run lines from the two ports on the T'stat housing to each of the elbows."
