First of all, be prepared that the props may not be correct for you. A WOT RPM test must be performed, in order to determine which props will work.Thanks for the reply, that is very helpful. The DP lower came with the aluminum props so I am set there. I was also told I would need the long spline coupler and that was included as well. Don't have the roller bearing race so I will get a new one, any suggestions on where to purchase this?
This is going on a 24 ' Sea Ray so not really a small boat. How would I confirm the gear ratio on the lower?
Thanks again for the help...![]()
I'm hoping that Andrew does not mind me sending you to the Vault "shimming procedure when changing lower units", rather than me typing all of this out for you. You'll find that I have explained it fairly thoroughly.I was finally able to clean the carrier off and read the numbers. It is 1.95 .....................
My next question is would you recommend a newbie that is mechanically inclined try the swap himself. .........................
At the same time I want this to be right and can't afford a mistake that damages my drive.
There is a local shop that is a Volvo Penta dealer that estimated $ 300 to do it for me. Is that good?
My fear is the shimming procedure and the preload. I am not familiar with it and it might be worth the $ 300 for the peace of mind when I get this in the boat and turn the key...What do you recommend?
