I am a new member and I have a 1986 Evinrude 4 hp Deluxe that I picked up some time ago on eBay. The seller "didn't know the condition" but it looked good in the photos. It turned out to be seized.
I probably should have cut my losses but I picked up another power head which didn't have the electronics but I figured I could switch everything over from the seized one. Although I never worked on this later model before I took my time and switched everything over but I'm not sure if I got it right. The power heads were interchangeable but not identical. I think the replacement may have been a few years earlier.
I wasn't getting a spark so I walked away from it for longer than I'd like to admit and just now picked up on it again. I wonder if I can switch over to an earlier 3 or 4 hp stator, flywheel, points and coils etc. This arrangement worked for years and was basically bulletproof. The CDI power pack and coil set up is costly to replace and tough (for me) to trouble shoot. Has anyone tried this conversion before? I have several old 60's and 70's 3 and 4 Johnson and Evinrude motors that I have picked up for parts or restoration along the way but I'm not sure if the parts will interchange. I like the gear shift and rubber mount isolation of the deluxe. Any tips or suggestions?
