shavedhead
I have a 1999 50 h.p with merc.commander 2000 controls, I bought a tachometer adapter to plug in to harness at controls,Purple wire is switched power and that is fine, gray is sending unit and Blk is ground,When I tested the power wire with voltmeter it test fine,except the ground wire is not grounded coming from plug in harness, I assume it should be grounded in the controls somewhere but must not be.any reason I cant just take that to a ground and then to my tachometer,I any wiring the whole boat and installing gauges,it never had any. Thanks for your help.
