Heres the issue. I fished all day no problems. Tied up at the dock to load. Cranked the motor went to put it in forward and the lever wont move. Put it in reverse to tie back up to the dock and it goes in reverse perfectly. Checked all the linkages and they seem to be solid. is there a part or something in the control box that could have broke to get in the way of the forward gear lever? I tried reverse numerous times and worked every time it just wont go into forward. By wont go into forward I mean I pull the release button and the lever wont even move forward. It will go in reverse every time. But if you are in neutral the lever will not go forward.
Motor is a 1993 Yamaha 40 HP 2troke.
