3-legged-dog
2003, sterndrive, Merc. 350, Bravo iii, fuel injection. I replaced the control handle, merc. gen 2 pistol grip with with trim control on the grip, bc the neutral lock was worn out.
Before, when turning the key to from off to start position 1 fuel would prime the injectors/engine, start position 2 would fire up engine.
now,
when turning the key to start position 1 "No prime." I have not tried to start bc of no water connection to engine, I will re-test with water asap.
did I blow a fuse or trip a C/breaker somewhere?
maybe control arm somehow not in neutral?
maybe a bad kill switch as I had to un-assemble and re-assemble to remove from side mounted faceplate of control arm and is currently installed now?
Thanks in advance.
now,
Thanks in advance.
