damroc
"hi everyone hope you all had
"hi everyone hope you all had a great season enjoying the water, i removed my boat last weekend from the marina for winter storage and noticed i found it hard to select forward and reverse gear. After checking all the cables i have isolated the problem to the cable connecting to the leg, it appears to be seized solid in neutral with no budging it. I have been told i cannot get at the other end of the cable unless i drop the leg, now im a motor mechanic by trade but dont want to remove if possible. Is their any way i can get access to spray some wd40 in or do i have to pull off the leg. Ye see its said you have to have the forward gear engaged to successfully remove the leg but as mine is stuck im a bit reluctant, any input would be great . Thanks"
