dcbullington
"Started having trouble with t
"Started having trouble with the port engine not being able to go above 2500 rpm (less than 50 hrs on both 327F's) so I checked the fuel filter and there was a ton of what looked like some sort of fungus, along with a fair amount of either sand or scale. I have a 1966 Cavalier with galvanized tanks. When I replaced the filter, she ran great for about an hour and then the same problem (only the port). This time she stalled coming into the dock and wouldn't re-start (got to practice single engine docking technique!). Drained filter, got a bunch of the same fungus looking stuff. Started right up, but I also noticed a lot of semi-burned fuel floating on the water near the port exhaust. Not sure what the significance of this is. My question: should I just run it and keep cleaning the filter until I burn through the bad gas, or pump it all out (about 50 gal) and clean out the tank or maybe replace it?
Thanks for any comments/help.
Dave"
Dave"
