Hi all,
I have a 1990 200 hp V6
Smokes a little at startup but runs fine and idles fine (for a 24 yr old motor).
It will run 30-40 mph all day long.
When I run up to 50 MPH, after a minute or so, the constant horn will sound.
My mechanic recommended coming down off plane, put in neutral and squeeze the fuel bulb and check for firmness.
If firm, he suggested disconnecting the horn, since they are prone to failure and the part is no longer available (apparently due to failures).
Any other advice or does this sound reasonable?
thanks!
thanks!
