foodwatch2003
I am considering adding electr
I am considering adding electric fuel pumps to my twin 1976 LM360's. The current configuration is stock using Carter carbs. Anyone have a particular suggestion for pump model? I assume I simply bypass the existing mechanical pump and then deploy an oil pressure safety switch to kill the pump when the ignition is on and the oil pressure is not present.
