Mikk Wardwell
I purchased a 1989 Johnson 88hp with no prop. The previous owner said he couldn’t find a prop to fit it and I’m having the same issue. Problem being that it has a 15 tooth spline with squared teeth. It’s supposed to have, I believe, 12 spline with beveled teeth. Can anyone tell me why this may be? Also, will a prop from almost any band outboard with the same size shaft work? What do I look for, as in what type of prop has the squared teeth? Or would I be better off replacing the shaft, as I have a blown Johnson 115hp and many parts are interchangeable? Thank you in advance and happy boating!
