dmbfanatpsu
OK so here is my situation: I have a 99 Johnson OceanPro 200 and we hit a reef pretty hard last weekend and damaged the lower unit in such that the entire lower unit needs replaced. Basically I had my mechanic look at it and in conclusion he said that he'll undo the entire lower unit and put in a replacement. He is looking for a used one and I suggested just buying a new one as such from this website http://www.sterndrive.cc/mm5/merchan...ory_Code=SE306 in which after the water pump, drive shaft, etc...will be around $1700. I spoke to the mechanic and told him this and he said that a replacement lower unit would should run around $7000-$8000 and that for $1700 it must only be the shell for the lower unit and nothing else?
So basically I'm trying to get my head around if the lower unit (in the link above) that cost $845 is correct if I'm replacing the ENTIRE lower unit or would I need that and additional $5000-$6000 worth of other parts to replace the lower unit?
