All plugs out.
If you use the key to turn the motor over you need to ground the plugs.
Use a jump box or a jumper wire.
The pics are a lead I fixed up to ground out my 3 cyl. motors.
When testing.
Remove all plugs.
Ground the plug wires if you use the key, or use a jump box.
Install tester.
Turn the motor over until the needle stops going up.(usually 5-6 rev)
Record the results.
The gauge? Yours might not read as good as another.
It could be as much as 20# difference from another.
So the results or actual poundage might vary.
Your looking to get the same or real close to each other.
My gauge reads correct. My motors both read 145# on all 6 cyl.(twin 85's)
That reading is for a healthy motor.
If it read any more than 5# difference between cylinders I'd be looking for a problem.
They say any difference of 10-15% is acceptable.
If I had 10%, that shows a problem.
Do the test and post the results.
