Compression Test values
backfire101
I have a 2005 Volvo Penta OSI-
I have a 2005 Volvo Penta OSI-E with 130 hours on it. Had a compression test done due to backfire problems and the results came back 168-180. Is this a good/acceptable range for an engine with so few hours. Thanks.
"I think the guidline is all c
"I think the guidline is all cylinders should be within 10%, which yours are. Based on the numbers, your engine is fine.
Have a great day,
Rob."
"Seloc is as permissive as acc
"Seloc is as permissive as accepting the lowest as 75% of the highest. I see no problem whatsoever with the compression values you posted, except that they actually look a bit on the high side."
