rmcderm313
Hi All,
I did a compression test on a recently purchased 25 HP 1987 Mercury. It doesn't run so I had to do the test cold. My results were 120 psi on the top plug and 140 psi on the bottom. Is that a concern? It's outside the 10% differential range, but what does that mean?
I tested the spark and I am getting a spark in both plugs so I'm going to move on to cleaning the carb to see if I can get it to start.
Any thoughts on what I might expect if I can get it to start? Also, is it possible the compression difference has something to do with it not starting?
Any help appreciated.
Thanks,
Rob
Here are pics of the results:
Thanks,
Rob
