Back to drawing board. Took it out for another test run this morning, new tank, new gas line and bulb, and fresh gas mixed to the proper ratio.
She started up fine, and got right up on plane and ran great, for about 20 seconds, then began surging badly and kept it up until I let off the gas. After that, for the next hour or so, when I'd try to get on it she would sometimes try to accelerate but just before getting up on plane would start surging again. But other times it wouldn't even try to accelerate, just bog right down as soon as I tried to give it some gas.
I tried pumping the bulb while it was running at least a dozen different times, and one time, but only one time, it got up on plane and ran fine for a short distance before starting to surge again. All the other times when I pumped it up while running it made no difference at all. The bulb did pump up readily every time, which is big improvement over yesterday so I guess the new tank did solve that particular problem.
Things done so far, in order, compression test (with iffy results) seafoam, spark test, , new hose and bulb, thoroughly cleaned carbs, but put back together using original parts, new tank, fresh gas. It ran like a champ for several miles yesterday before it suddenly bogged down, no surging, just bogged down. The surging this morning is a brand new symptom.
I'm stumped, symptoms keep changing with every new thing I do. I guess I'll tear the carbs down one more time, clean again but install new carb kits this time instead of using original parts since I now have the kits on hand. Also will tear down fuel pump and clean it but don't have a rebuild kit so will put it back together using the old parts unless I see a problem like a torn diaphragm or something obvious like that. Then back to the river for another test run, hopefully tomorrow if I get it all back together today.
Any ideas of what else I can try before heading back to the river again? Thanks
