2001 5.0 Mercruiser Alpha carbed in a 22' Stingray. Boat just wasn't running quite right the last two times i had it out. In the slow speed zones (about 1400 rpm) it was surging slightly. Seemed ok at cruising speed. At WOT it did not have the power it normally does. I could normally get 4900 RPM at 50 MPH (GPS speed), it would only get to 4400-4500 RPM at 45-46 MPH with a slight poping, like a backfire out of the carb.
I decided to do a compression test on the motor hoping it would give me some piece of mind. Well, now i am scared. Engine warmed up, throttle open. Here's what i got:
#1-180 #2-120
#3-180 #4-170
#5-160 #6-140
#7-180 #8-130
I repeated the test several times. numbers would change 10-15 psi on the lowest cylinders, would change about 5-10 psi on the highest cylinders. But the high ones stayed high, low ones stayed low.
What does everyone think?
#1-180 #2-120
#3-180 #4-170
#5-160 #6-140
#7-180 #8-130
