compression specs
Hi,
I don't have access any longer to the service information (shop manual) but I know that, when new, the compression specification was right at 200 psi.
After one is used a few hundred hours, that can fall off significantly.
But, a well maintained Honda 40A with 150psi compression will still probably give years of reliable service.
And, with admittedly a bit less power, they will typically start and run ok with 120psi or even lower.
Good luck.
