When you resleeved the motor did you also go through the carbs at the same time? Motors blow for a reason. If you don't fix that reason you're doomed to blow again. I do a lot of work with 2-stroke jet skis and it's extremely common to see one cylinder fry and people just assume the 'oiler' went bad and toss it in favor of pre-mix. 99 times out of 100 if you dig deep you'll find a carb that was plugged or a gasket problem that led to the lean condition on that cylinder alone.Sound like damage to another piston to anyone else? If so, what could cause this for a second time in less than a year? Lean condition? VRO failure?
